Cloud of smoke comes out when start my car
Old 07-18-2011 | 01:58 AM
King Kong28's Avatar
Exclamation Cloud of smoke comes out when start my car
When i drive around and turn my car off and on, and when i turn it on again, a medium sized cloud of smoke comes from the exhaust. What could that mean?
Old 07-18-2011 | 05:04 AM
bw_hunter's Avatar
Re: Cloud of smoke comes out when start my car
Valve guides or seals.....
Old 07-18-2011 | 08:36 AM
my1994z28's Avatar
Is the smoke blue or white?
Old 07-19-2011 | 12:48 AM
Smoke is blue, it only happens once the car has been ran and it doesn't happen on every start.
Old 07-19-2011 | 02:03 AM
L.dookie's Avatar
blue smoke is oil. most likely it is the valve guide seals.
Old 07-19-2011 | 12:31 PM
boostedz28lt1's Avatar
I agree with valve seals or guides.... easy fix.
Old 07-23-2011 | 12:43 AM
what can be an easy fix to that?
Old 07-23-2011 | 08:05 AM
dennis5374's Avatar
Pull the heads and have them done at a machine shop. Not easy but your best option. Or buy a used set off here or ebay for 200 and slap them on and call it a day
Old 07-23-2011 | 11:42 AM
95zsean's Avatar
Replace the valve rubbers. You can buy or rent a valve spring compressor and change them your self. On a scale of 1 to 10 it about a 7 because you must make sure the valve does not fall into the cylinder. the best way to do that is to bring the piston to top dead center and when your done you can re-adjust the rocker arms on that cylinder.
Old 07-23-2011 | 06:02 PM
Procharged94Lt1's Avatar
Just a time consuming process- when I did them on a friends car- we took the time to swap plugs too- I took a small length of rope and inserted it into the spark plug hole- about 6-8" worth and then rotated the engine by hand until it was tight- the rope will be sure to keep your valves from dropping down at all- making your job even easier.
Old 07-23-2011 | 09:07 PM
walt355's Avatar
If you have a leakdown tester(of crafty you can make a tool) to put compressed air in the cylinder. Then you can remove the valve springs without dropping the valve, It is a good idea to take a hammer and lighly peck the valve springs to unstick the keepers before you compress the spring.
jj71787
12-30-2014 02:15 PM
Red97LT1
9
12-17-2014 06:13 PM
jayblev95
12-01-2014 06:55 AM
teedoff59
08-08-2002 01:36 AM
Quick Reply: Cloud of smoke comes out when start my car
