Clutch fork Help!! Removing tranny from engine
So I got the tranny and the bellhousing bolts out, Ive read numerous threads, Ive got my damn clutch fork on bearing, how do I get the fork out of the way so I can remove whole tranny from engine.. it only slides out few inches until the clutch fork stops from removing the rest of the way.. any clear instructions on this??
Re: Clutch fork Help!! Removing tranny from engine
that's what it seems suppose to do when I read other threads but wouldn't pull straight out... I barely got a socket in there and removed the bolt that holds the fork in there and took it out. I know I don't have to do this, but it was the only way I finally got it out. thanks anyways!! appreciate it
Mikes 1994 z28
11-25-2014 02:00 PM
Doug Harden
11
07-14-2002 04:31 PM
