Code 21
Code 21
I cannot get it to run unless I give a some gas then it ifles horribly. The only code I am pulling is Code 21 which I think relates to the TPS voltage.
But if I let it try to idle and just kills itself.
Any suggestions?
thanks,
Howard
Any suggestions?
thanks,
Howard
Re: Code 21
Start with the obvious. Key on, back probe the TPS to see if the grey wire has 5 volts referenced to the black wire. Then see if the blue wire varies from about .5V to 4.9V when you swing the throttle plates from closed to WO. Your fault indicates the blue wire is not going below 2.5 volts. If that is the case, Disconnect the TPS and check the voltage on the blue wire. If it's not at or near 0V, chances are the blue wire is shorted to a voltage source. The hard part will be finding the bad spot. Luckily the blue wire only goes from the TPS to the PCM if that is the case.
If it goes to 0 when disconnected then the problem is inside the TPS. Be sure to check the plates to be sure they are closing properly.
Re: Code 21
Ahh found a wiring issue. I have a custom setup and the motor is actually in my S10. I had gotten backfeed of voltage from a boost gauge some how. I corrected the wiring the voltage went back down and everything runs fine.
Re: Code 21
Originally Posted by Injuneer
DTC-21 = Throttle Position (TP) sensor circuit (signal voltage high)
I thought that set when the TPS voltage exceeded 4.90V????
It is the 1994 GMP/94F-2 manual from Carline bought from Helms BTW.
johnsocal
08-29-2002 10:01 AM
Darth Xed
14
08-07-2002 12:21 PM
BigDarknFast
3rd Gen / L98 Engine Tech
07-08-2002 01:37 AM
