Code 27?
Re: Code 27?
It's for the trans. Is yours manual or auto? You really need to set up a "Signature".
In any case, a problem with torque converter lockup, or the reverse lockout solenoid will not prevent the engine from starting.
Describe what happens when you turn the key to "start"?
Re: Code 27?
I'm very sorry. I thought I set the signature. I'll not use my phone and try from computer.
T56. Check engine light flashes. Gauges all work or light up. Low coolant light comes on(popped up too before I parked car). I literally not sure if luck or not but took the block out of block and with wire connected ground it out and the car started. I drove into house and parked. Than I tried from that wire to see if there is spark with a screw driver and didn't see anything. Once again sorry about the signature. I'll do it tom
Re: Code 27?
He has a 93... the ECM with the quad driver modules. Always check Shoebox's code list:
http://shbox.com/1/Dtcs.htm
93 differences are shown in the far right hand column.
When you use a phone, it seems like it just makes everything harder for the people trying to help you, particularly with the "signature".
Quad-Driver Module (QDM) #2 circuit
applies to:
- 4L60 TCC control and temp switches
or
-T56 reverse lockout
applies to:
or
Re: Code 27?
Sorry for being all over the place. After I did that tuneup and had injectors cleaned and tested the car ran and was driven for last 3 days. Yesterday while driving low coolant temp light came on. I check fluid was low so I added alittle. Parked car for 5 mins. Than went to drive and only cranks. Nothing else. So I decided to see if there was spark and grounded a plug wire and the car started. So I replaced boot back on plug and car doesn't start. Flashed it and gave me a code for 02 sensor and that code 27. Hope this clarifies situation.
Re: Code 27?
Thanks again...
