codes P0300 P0420 p1411
1996 camaro z28 man 6 speed w/air
My car suddenly ran rough almost stalled , 30 sec later really rough flashing ses lamp.Check gage light on now also.
I stopped and scanned. codes p0300 p0420 p1441.
p1441 i am familiar with and was aware of this 1 week prior to current issue.
Now car will not turn over. loud clunk and smell of gas.
Any suggestions for order of diagnosis?
Thanking you in advace for your help .
Triple black 96 ss
Cheers
Triple black 96 ss
Cheers
Always a lot of confusion on what terms mean..... what do you mean by "will not turn over"? The starter does not engage? ... the starter engages, but will not cause the rotating assembly to move at all? .... the starter cranks the engine over, but it will not start?
When you say "i am familiar with and was aware of this 1 week prior to current issue.", do you mean you were getting those same three codes at least a week before the engine decided not to "turn over"?
The starter engages, but will not cause the rotating assembly to move more than what seems to be one cylinder ? The starter does engage( just so you are aware I replaced it 2 weeks ago ). A week ago the only code was P1441, Im familiar with it because it is the 3rd time dealing with it.
I checked the oil level and color look fine.
Thanks Speedy, I'm having the car towed to my friends shop so that working on it can be done by me on the weekend and after work hours.Thats where I'll pull the plugs.
However , tonight i'll check the oil for fuel and report back tonight.
oh oooh............ lots of gas in oil. Unmistakeable as you said.
Engine completely done ? What do you think ? should I be placing ads "WTB 96 Camaro LT1 engine "?
Smiling on the outside ,Crying on the inside.
Cheers
Cheers
Doubtful it's damaged, you're probably OK
Judging from the way you described the event. You are probably ok. You will want to pull up the fuel rails and turn on the fuel pump to see if any are leaking. Then attach a vacuum pump like a mity-vac brake bleeder to the FPR to see if it holds vacuum.
I would then pull all the plugs and while you have them out, check each one for spark. Then check each cylinder for compression if not leak down.
