Coil Packs! How many & Locations?
Old 02-23-2007, 04:24 PM
Red97LT1's Avatar
What would be some symptoms of a bad coil pack? Thanks
Red97LT1 is offline
Old 02-23-2007, 04:28 PM
zx1216's Avatar
well your car should have only 1 coil mounted on the driverside head i think. Not too sure about the symptoms, maybe if it breaks up in the upper rpm's
zx1216 is offline
Old 02-23-2007, 04:30 PM
BUBBA's Avatar
I await the answer to this question---since I don't know what the question is---unless you are referring to coil-on plug "packs" aka LSx ig system---becuase an Lt1 has only (1) coil to my knowledge. Someone please respond so that I can say that I learned something today. THX.
BUBBA is offline
Old 02-23-2007, 04:37 PM
2000GTP's Avatar
There is a single coil on the LT1 engine whereas the LS1 has 8, one per cylinder. Here is the location: http://shbox.com/1/coil_loc.jpg
2000GTP is offline
Old 02-23-2007, 05:00 PM
97WS6SCharged's Avatar
Quit messin with the poor guy. We all know the LT1 has 8 coils just like the LS1.
97WS6SCharged is offline
Old 02-23-2007, 05:05 PM
Red97LT1's Avatar
Thanks I am getting a random misfire code every now and then. The car will run fine for a week and then the SES pops on. The car runs fine and then I feel a slight stumble which results in the misfire code. Plugs,wires,opti and injectors have been recently replaced,so I was going to go ahead and replace it since it's the stock one I'm sure and it's only like 35.00 bucks.
Red97LT1 is offline
Old 02-23-2007, 05:24 PM
OBE1 95Z28's Avatar
It can get costly just swapping parts! Double check that all your plug wire boots are fully seated on the plugs and opti. Did you apply dielectric grease to the plug boots?
OBE1 95Z28 is offline
Old 02-23-2007, 05:27 PM
Red97LT1's Avatar
That was the first thing I did and I did apply dielectric grease. It only does it every now and then. Start the car and it idles fine one day then the next day when I start it, it stumbles and sets a code. It even will stunble slightly for a second it drive and then smooth out.
Red97LT1 is offline
Old 02-23-2007, 06:31 PM
moparman's Avatar
Is P0300 the code you get?
moparman is offline
Old 02-24-2007, 09:43 AM
Red97LT1's Avatar
Yes it was at one point. I f i hooked up my code scanner after the light came on,then the scanner would only give me the p0300. When I hook the scanner up and run it while driving,the code sets and the scanner picks up the cylinder the misfire occured on.(PO307) I am going to switch plug wires to see if the code jumps to another cylinder.I think that I may have a head gasket going bad.Here lately my coolant level keeps dropping.I have checked the oil and no signs of water.
Red97LT1 is offline
Old 02-24-2007, 12:49 PM
Red97LT1's Avatar
Unhooked the #7 wire and I got the same P0307 code and I couldn't tell any difference between the time it was attached and when it wasn't. Maybe a bad wire? going to replace just that one and see what happens.
Red97LT1 is offline
Old 02-24-2007, 01:10 PM
moparman's Avatar
#7 is the cylinder giving problems. Either wire or plug.
moparman is offline
Old 02-24-2007, 01:49 PM
Red97LT1's Avatar
The plugs are brand new ac delco platinum that were put on yesterday by my mechanic in hopes that that was the problem.The wires are new also. I replaced the #7 cylinder wire with another one I had and it still showed the code. The car will run fine then I get a code. I'm running out of things to check. I'm thinking head gasket since the problem still exists and I'm loosing coolant every couple days.
Red97LT1 is offline
Old 02-24-2007, 02:11 PM
Try swapping the #7 injector with one from another cylinder.
Injuneer is offline
Old 02-24-2007, 02:16 PM
Red97LT1's Avatar
That injector is brand new.Put on yesterday.Could it be bad? How hard is it to swap them?
Red97LT1 is offline
Quick Reply: Coil Packs! How many & Locations?
