Cold air intake question
#17
Re: Cold air intake question
Originally Posted by SS RRR
LMAO... have you ever seen the SLP LT1 CAI? It looks like two ~ 2 1/2" black PCV pipes. Yeah it's an engineering marvel.
Velocity is not a concern in a CAI. A CAI's purpose is to make clean, readily available air w/ as little restriction as possible.
#18
Originally Posted by 1995greenTA
Im not for sure on this, but can you get accurate measurements of air flow, just from the dimensions of something?
#19
Originally Posted by Silver
But, do you know about fluid dynamics. That's the key...
#20
OK here is my two cents on the subject. From the air filter to the plenum you want the least restriction possible at wot. Remember it is atmospheric pressure that is filling the plenum. Ideally you want zero pressure loss from the atmosphere to the plenum. Also the colder the air the better.
Now from the plenum to the intake valve is a whole nether matter. Here is where velocity takes over. With the proper intake manifold and heads it is quite possible to get over 100% volumetric efficiency.
#21
Comming from someone who did build their own CAI. You are better off buying one. I spent allmost as much on stuff to build it myself as a kit cost. Finding cone filters may be hard at a local parts store. I ended up using this verry tall can type filter, wich screwed the whole allignmnet needed way off. I will eventually buy one to replace my "custom" one. I think i used a link from www.f-body.org
94z28jbw
09-08-2002 03:22 PM
slothgrant
08-22-2002 03:01 PM
squirrels
07-13-2002 01:58 AM
