Cold start bottom end rattle.....
Well I fired my car up this morning and I just did an oil change and I put in the usual Valvoiline 10W30 and now at about 2K thru 2500 in first I have a light but noticable rattle till the motor warms up to normal operating temp (about 170-180) and the oil pressure drops down from about 60-70psi (when cold) back to 20-30(when warm). How long will it last like this if i take it easy? Is it too late to stick a new set of bearings in it? Thanks for all your help.
Jeremy
Jeremy
Re: Cold start bottom end rattle.....
Jeremy
Jeremy
The LT1s are pretty bad at piston slap when the motor is cold. If you're hearing that, don't worry about it.
Mine does that every morning, always has. I take it easy on the throttle and shift at low RPMs (<3000) until it heats up. It doesn't seem to make as much noise in the lower RPM band.
Thomas.
Thomas.
Thanks for the info guys, I was really worried. This is my first winter with my LT1, had an L98 befor, and I noticed that the other day. The noise made me really sick. I was already priceing rebuild parts for a 396 lol. Still might build the 396 though. HEHEHE. Thanks agian.
10-31-2016 11:09 AM
Gtpguy
01-26-2015 04:50 PM
01-23-2015 01:13 PM
jrp4uc
26
07-09-2002 04:37 AM
