Comp R lifters
Mine are sitting in the garage in perfect shape. They lived through not being adjusted right for 50-60 miles and then worked great for a thousand miles, after thet were set correctly. They would still be in if the intake didn't need to come off a few years ago and I wasn't worried about all the bad publicity they were getting.
I have some of the original ones I used for a couple thousand miles. I put them in a box and just looked at them as they have been sitting for a couple years. Look good. But I am curious as to why you want the "junker" hard to adjust ones that have bad publicity?
Can you fix the newer versions. I would think a simple wire retainer would suffice, instead of the cups that break.
Good ones are wire retainers, at least there was never bad press with them 'The ones with Cups in them are what the bad reviews are about.
Well I just checked them, and there the old design, (good ones). I bought them right when the newer style came out. Must of lucked out and the supplier still had some old stock on the shelf. Good to know if I try selling them, someone will at least be getting a decent product.
