Convert engine from MAF to SPEED DENSITY
Is there any way to specifically go from a MAF engine to speed density? I have a painless harness for a speed density LT1 but I found some cheap LT1 engines. So I need to know quick. Well here's the thing. My harness is a painless harness made specifically with no MAF connector. Also I have to use a specific computer with this harness or it won't work (I had to have a certain part number computer). So there is no way I can send this back. And I found a engine really cheap. I can get a COMPLETE LT1 shortblock for about $300 OR I can get one with heads complete and valve covers for $750 so I need to know if I can convert the ENGINE specifically to speed density. OPINIONS NEEDED!!
Here's what I mean. I need to know what to add or take off of a engine with a MAF sensor to make it work with a speed density computer/harness? swap timing covers, anything? Or just take the MAF sensor off and put a piece of piping in it's place?
Yes, If you guys actually read his post. He ALREADY has the speed density WIRING and PCM. He wants to know how to covert the ENGINE to spped density
Anyway, You computer and harmess should run any LT1. The engine itself doesn't care if it's being run by SD or MAF. Just plug in your harness to the sensors and don't put a maf sen. in the air intake. The only thing I can think of is maybe your harness does or doesn't have a crank sensor hook up. If it doen't you could still buy any year and just not hook up the crank sensor, your system will still run it. Hope this helps.
Originally posted by n2oCamaro
Mike, I am not seeing the where rear 02s are a factor here. Afast, is this going in your 83?
Thanks, Diablo Z. there for a minute I didn't think anyone was understanding what I was saying Well guess I am going to buy that engine then
Re: Convert engine from MAF to SPEED DENSITY
Originally posted by AFast83z28
I have a painless harness for a speed density Also I have to use a specific computer with this harness or it won't work (I had to have a certain part number computer). So there is no way I can send this back.
Anyway good luck with the project. The Painless wiring will make it really easy to get running.
Thanks Diablo. Don't worry about the mix up N20. The painless harness looks super easy to install. I just need to figure out how far I can put the computer from the engine. I would like to have it under my dash but I don't know if the wires are long enough. I will update everyone as I go
F'n1996Z28SS
08-23-2023 11:19 PM
formula218
12-02-2014 04:27 PM
07-04-2005 05:00 PM
