Converter Lockup ??
Actually the answer is no. The stock program commands the converter to stay unlocked at WOT. It might lock when you get it up to speed but once you go WOT for the pull it will unlock.
If you install a lockup switch or program it to lock at WOT (this is hard on the lockup clutch, can burn it up eventually) your HP will be higher...more comparable to an M6 dyno pull because you will be removing the power-robbing converter slip.
If you put the shifter into 3rd and cruise it will lock up in 3rd...but in normal driving it will go to 4th before it has as chance to lock in 3rd.
Originally posted by Chris 96 WS6
The fact that the converter does not lock is why A4 dyno numbers are always lower than the same setup with an M6.
Agreed. You can wire up a switch for OBD1 cars easily, OBD2 it doesn't seem to work or work well. But like Rich said, I would not recommend making a habit of locking it under WOT..the clutch will eventually burn up and you'll lose your lockup all together.
VIgilante sells a multi-clutch disc converter if you want to lock up under WOT.
For the switch, just do a search for lockup switch...there are several posts on the subject.
NewsBot
09-14-2015 02:02 AM
GusarskiSS
Exhaust System
09-02-2015 03:51 PM
