coolant dripping on the passanger side floor
i've been using my heater the last few days and today, i noticed a big puddle of coolant on the passanger side floor...it appears to be dripping from under the back of the glove box....help please.
Originally posted by LT1TONY
Just wondering is your windshield fogging up as well.
Sounds like it might be heater core related if it's on the inside passenger floor.
YES!! YES!!! YES!!!!!!!!!!!! you got it RIGHT ON THE HEAD!! damnit! i noticed my winshield fogging up today, and i've never seen that before...i thought it was odd.
how much do those things cost anyway?
edit: oh yeah, will it stop leaking if i dont use the heater? or will it leak until i replace/fix it?
Not really too sure on how much the newer ones like this go for. I'd call your local auto parts store and see if they have it in stock and ask how much. I know the ones for older GM cars are about $35-$50 bucks. Not sure as to how hard it's to remove too.
I know a lot of other guys on the board here have removed them for weight, so hopefully some one can give you an idea there.
If your going through all that trouble, I really would put a new one and forget about an old one. You don't want to have to tear it out again.
It does get worse and will fog up even more.
weight, eh? hmmm *scratches chin,* so, how difficult is it to BYPASS the heater core then? HOW do you bypass it?
any detrimental effects to the motor?
ok, uhm, any hinters on how to EASILY change out the heater core? is there a good way other than takin out the friggin dash?
A new heater core from Autozone was under $50 I can't remember exactly how much I paid. It took under and hour to swap in the new one. Just pull out the glove box and take off the black cover. And disconect the two lines in the engine bay. The hardest part is getting those clips back one.
