Coolant dye with a blacklight..where to get dye?
The mechanic shop still couldnt find where my leak was coming from with a radiator pressure tester...he told me about the dye you can put in there and then use a blacklight...anyone know where I can get this stuff from/how much it is?
Yea you can either go to Pepboys or Auto Zone. I had an oil leak that I could not figure out where it was coming from so I got the dye and the light and it worked out great. You will also need the special glasses in order to see the dye.
