coolant fan
coolant fan
Apparently I have a coolant fan problem. While the car is moving it cools fine. but as soon as I get in traffic or lights the temp begins to climb. I have a 97 Lt1. I am new to this vehicle. Most likely cause? Relay?
Any input appreciated
Thanks, Glenn
Thanks, Glenn
That would be http://shbox.com/1/4th_gen_tech1.html.
All cars with electric fans heat up when you stop. That is normal.
Info.
Info.
More than likely a relay. Hopefully not an ECU signal interuption. Those can be a pain to track down.
Doesn't sound like he has a problem at all, just normal for the conditions in which he is driving. If his temp gauge was pegged in the red, then I would start to worry. You also have to figure these cars do run warm from the factory.
Magenta_Hearts
03-29-2017 08:54 PM
