coolant gauge problem or what?
had an overheating problem-- cracked radiator. fixed that and it has ran great for a few hundred miles. also replaced the thermostat at the same time. the last 3 times driving it though it's almost overheated. it will climb up to about 235 or higher, just before the red and stay there for a while (10 miles), then all of a sudden it will drop back down to 200* in about 1 second and then it's good to go for the rest of the trip 10 miles or whatever.
when it's that high i don't hear the fans click on. i know they do work though, as they're on when you start the car. don't think it's a fan issue. it is that hot when cruising on hwy at 60mph which ought to be enough to cool it like the fan.
sounds almost like a stuck thermostat to me, but damn it's new.
car runs great otherwise. plenty of coolant. doesn't seem to have any air bubbles and has went through a dozen cooling cycles since radiator install. also has a new radiator cap.
got me thinking if it might be a bad coolant temp sensor.
any ideas? thanks
any ideas? thanks
the bleeder screws don't bubble. should I just keep letting them bleed out? like i said it has been through a bunch of heat cycles and 200-300 mi since radiator install. how much is enough? come to think of it this did start up after i ran it pretty hard... might have churned up some bubbles somehow? thx
Magenta_Hearts
03-29-2017 08:54 PM
99TransAmWS6
02-12-2015 07:23 PM
