coolant leaking
Passenger side? Like where it is attached to the block? That would just be a gasket or your mounting bolts have loosened. The typical place they leak is out of the weep hole on the bottom. That would indicate you need to replace your pump.
hi again
upon further examination i discovered that one of the bolts was loose, so my question is do i still need to replace the water pump or just the gaskets. I was also wandering what would be the cause of this problem happening so i could try to avoid something like this happening again, and thanks for your help.
There is a small weep hole on the underside of the water pump. I put my finger on mine which causes any drips to go down your finger. This is probably what it is and not the gasket.
I agree, change it fast
Re: hi again
Blood type Z28
04-08-2015 11:34 PM
