Coolant Level Sensor NIGHTMARE!
Old 06-04-2009, 05:28 AM
  #16
ACE1252's Avatar
Originally Posted by userchemical
Just my 2 cents but i would NEVER EVER try and fix a leak with "sealant pellets" or any other method, all you're doing plugging up your rad, water pump, thermostat, and everything else.
Hehe this is old, but I just saw it.
I didn't have any leaks at all. The GM service manual says to throw in two of these pellets whenever the system is totally drained.
I did manage to check my coolant sensor. It did have some buildup in it. I have cleaned it out and still have the low coolant light almost every trip. Either my sensor is crap or I may have an electrical issue. I have unplugged it to see if it comes on or flickers...if not, I'll buy a new sensor.
ACE1252 is offline
Old 06-04-2009, 06:44 AM
  #17
DAVE00's Avatar
Just pick up a new one from Rockauto.com and save yourself the trouble. Mostlikely cleaning it wont do the trick as they get deposits and build up on the sensor rod and go bad. Poor design by GM.
DAVE00 is offline
Old 06-04-2009, 09:13 AM
  #18
khojo16's Avatar
mine went away after i cleaned the ground contact for the wiring...ended up grounding my MSD box and electric water pump at the same spot, and all has been well ever since
khojo16 is offline
Old 06-05-2009, 08:17 AM
  #19
CobraEatr's Avatar
Mine went away after I drained and flushed the coolant. It wasn't low, but the water was over 5 years old and was black. It stunk really bad as well. Once I put in the new stuff I had to top it off again after a few miles of driving. Now the system is full and the light is off.
CobraEatr is offline
Old 06-05-2009, 10:10 AM
  #20
bw_hunter's Avatar
Black, stinky coolant is not so good......
bw_hunter is offline
AlaskaZ28
01-01-2015 12:30 PM
AlaskaZ28
12-16-2014 07:24 PM
AlaskaZ28
12-10-2014 02:39 PM
AlaskaZ28
12-10-2014 02:37 PM
91Bird305
08-08-2002 12:36 AM
Quick Reply: Coolant Level Sensor NIGHTMARE!
