Coolant light comes on...
Ok, randomly my coolant light will come on, but not only when it's hot, or only when it's cold. Just random. I've checked my coolant level numerous times and it's always fine. The car runs a constant 180-200 degrees(stock thermostat), and rarely will jump to 220 when I sit for a few minutes, but NEVER gets close to overheating. Is there a chance my coolant level sensor could be bad? Or is this a common problem?
Thanks for the help,
Kyle
Kyle
Just clean it. Take out the battery, the sensor is right at the top passenger side of the radiator. Lower the coolant level. (I siphon some into a gal. jug.) Slide off the spring clip and wiggle, pull out the sensor. As long as you have to small prongs sticking out of the sensor still you can just scrape them clean with a pocket knife. Try that before you buy one. It worked on mine. Make sure you air bleed the system of course. Later>>>>>>>
Location: Austin, TX or Texas State University at San Marcos
Yeah it is really common and mine is doing it right now too. I think shoebox has a R&R on how to do it on his tech page if im not mistaken. Or he atleast has a picture of where it is and what it looks like.
Chris
Originally posted by Euclid
I just unplugged mine, tucked the connector by the battery.
that light drove me crazy!
