Cooling fan temp
Cooling fan temp
i am having a strange problem with my car. For some reason my radiator fan does not turn on till 240 degrees! i have a 180 deg thermostat so as long as im moving the temp is fine, but if i idle...it will keep getting hotter and hotter and no fan till like 240. i replaced the coolent temp sencer with no luck. is my computer set to turn them on to high or is there something else? i need to fix this before summer!
Yea, that is really weird cause OEM temp is 180 thermo and thats what i got in there....thats really werid that it waits sooooo long to turn the fans on. the it gets real close to that red mark. thanks for lettin me know thats normal
Originally posted by Bobsep84
Do you guys know what the OEM fan turn on temp is?
It's likely that you have air in your cooling system. The presence of air will cause your themostat to open late or not at all, thereby causing your engine to overheat.
When you car is moving you're forcing the coolant through the system since the water pump is working harder, but at idle the coolant recirculates at a slower rate thus overheating.
I'd try bleeding the air, this is the cheapest solution (free) and most likely problem.
Wallace
Wallace
Yea, i bleaded the system of air already. the problem isn't there...the problem is the radiator fan not turning on when the engine reaches a certain temp. i have no idea what could cause this. by the way, turning on the A/C does turn on the fan like its suppost to
