Cooling issue :mad:
Cooling issue :mad:
Ok, so my car overheated a few weeks ago. I figured no big deal, I'll just flush and refill the system right? Well I just got through with attempting it and I'm baffled. I flush the system until the water runs clear (almost) and then fill it up with straight water to check that everythings ok before I add the antifreeze. So I get it up to temp and let it run for a little while. I filled the overflow tank and bled the air first too. So I go to check and what do I find? Well the radiator has some coolant (I guess it was full) but I check under the thermo, the water pump is bone dry. But it gets better, not only was it burning coolant (sweet-smelling white smoke) but f'n coolant is coming out of my exhaust tips and through my cutout. So I naturally figure a head gasket blew out (f/n awesome) but I'm not sure. Could a bad head gasket actually leak enough that unburned coolant drips from the tailpipe?
I'm stumped really, does anyone have any ideas? Anyone experienced similar?
10-31-2016 11:09 AM
