Corvette WP on an F-body w/ oil cooler delete
Old 03-14-2013 | 10:39 PM
1TUFFZ's Avatar
Question Corvette WP on an F-body w/ oil cooler delete
Hey everyone,
I am in the process of building my 396 LT1. I am going to delete the oil cooler and i am going to buy a water pump. I want to stick with the mechanical pump because this will be mostly a street driven car with a little strip and road racing action.
Rather than buy an fbody pump, and plug the hole I was thinking of buying a Corvette pump since it doesn't have the cooler fitting in it.
Has anyone tried this? The only thing i see is a problem is the upper heater hose pipe on the passenger side. Does anyone think the heater hose would be long enough if you cut the 90* portion off of the rubber hose? Or is there anyway to straighten a prebent hose?
Any help is appreciated,
Aaron
Old 03-15-2013 | 09:40 AM
KW Baraka's Avatar
Re: Corvette WP on an F-body w/ oil cooler delete
Wow......make it easy on yourself.
Buy the F-body pump, plug the hole, and be done .
KW
Old 03-15-2013 | 11:34 AM
PWR SHFT's Avatar
KW
I second this. First its not hard to plug the hole. Second, good possibility the vette pump is more expensive than the fbody pump.
Old 03-15-2013 | 11:48 AM
bw_hunter's Avatar
There is no extra hole on an f-body pump on cars with an oil cooler. The pumps are the same whether you have the cooler or not. Cars without the cooler use a different hose connecting the pump to the radiator instead of to the oil cooler.
Use the stock pump and buy the hose and be done all neat and clean....
Old 03-15-2013 | 12:47 PM
slick1hunting's Avatar
I wondered if it wasn't what bw hunter said as I know my pump is stock and I dont have an oil cooler. On a secondary note the heater hoses are able to be replaced in sections. Each point the rubber line connects to the hard line is removable and repairable with new rubber hoses and clamps. The clamp from the factory is pretty easy to remove with hacksaw or dremel and then peel it away. You have to be carefull not to cut into the rib on the hardline but its pretty easy to cut the factory clamp off. I found good instructions for doing it with a search and I think it was on an impala forum.
Posted from Camaroz28.com App for Android
Old 03-15-2013 | 01:06 PM
bw_hunter's Avatar
Whenever you want to see something a GREAT resource is Rob's page - shbox.com
Here is a link to the oil cooler diagram:
http://shbox.com/1/oil_cooler.jpg
And here is a link to the exploded radiator hose diagram:
http://shbox.com/1/95-97_hoses.jpg
The hose marked 'oil cooler bypass hose pn 10197675' is all you need to eliminate the oil cooler.
Really, really simple.....
Old 03-15-2013 | 01:45 PM
And here is a shot of the difference in the water pumps:
http://shbox.com/1/lt1_water_pumps.jpg
also, how to remove the factory hose:
4th Gen LT1 F-body Heater Hose R&R
Old 03-15-2013 | 05:17 PM
1TUFFZ's Avatar
Thank you everyone for your input.
Old 03-15-2013 | 09:08 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I used the bypass hose when I removed my oil cooler, but I think you can just plug the holes in the water pump and radiator.
Old 03-15-2013 | 09:11 PM
bw_hunter's Avatar
You'd have to block off a pipe on the water pump and another on the radiator. Just use the hose and make it really simple.....
HectorM52
07-30-2017 11:46 AM
HarleyZ28
10-05-2015 06:23 AM
armedtrigger
02-24-2015 08:30 PM
94B&RZ-28
12-22-2008 10:00 AM
97 RedSS
06-10-2003 07:58 PM
Quick Reply: Corvette WP on an F-body w/ oil cooler delete
