Could this be causing my problems?
While working on the opti, I noticed this out of the corner of my eye...Could this be causing my problems? I know it is probably a vacuum leak, which is what my problem is reminiscient of. Lousy idle, almost no vacuum, code 33 MAP high
And can you just remove it? This car has zero chance of passing an emissions test anyway.
Oh, and are there supposed to be 2 lines going into it? I can only find one...
DarkHorse
08-03-2002 10:17 PM
