Could I have really screwed up?
Coolant is about an inch below the full cold mark, after having been at the full cold mark 3 months ago. I guess I have a slow leak, but I've never seen any fluid anywhere.
Anyway, I had done a coolant flush, and afterwards had TONS of trouble getting the block plug back in because of the bolt that sticks out in the way. A friend of mine got it in eventually... but it would only go in 2/3 of the way... so idk if this could be the leak. It was in TIGHT at 2/3, which makes me think it was not going in 100% straight. Is it very possible that he would have had enough force to mess up the threads? I am really afraid to try taking the plug back out.
What to do?
What to do?
Re: Could I have really screwed up?
I wouldn't be so concerned - an inch below isn't all that bad. Just add more and keep an eye on it - check out the plug with the car running for any signs of leaking. Have you checked the cooland anytime between 3 months ago and now? Maybe it just wasn't topped off, or there were air pockets that are not gone so it pulled from the extra... Just add more and keep an eye on it.
Well, as you said - it could be as simple as that block drain bolt. If anything, the bolt threads would be screwed up, and bolts can be replaced. If its leaking somewhere else like the radiator, have it repaired as necessary. Could even look over hoses, etc. if you have done anything with them. One other thing is do not add any type of stop leak sealant or anything to the system. Just play it safe for now; maybe no leak will turn up and all will be well.
Also, seems like a slow leak (if any) as you said. So don't worry about driving it in the mean time. Just keep checking the level, and watch the temp gauge/low coolant light.
Hmmm, partially off topic. Mind if I ask what temps you saw before and after your 160* stat? I still have a 180, but even after my coolant flush and everything, sitting at a stop too long can easily put me jsut below redlines temps.
I'll tell ya when I know I broke my gauge temp sensor during my header install, and when I got a new one in finally, it was inaccurate and read over 40 degrees higher than actual operating temperatures. I was worried thermostat might be sticking, so finally swapped my 160* back in. Still read high, but twenty or so degrees lower (with madz28 tune, fans on at 205). So I do not yet have an accurate reading still because only today I went to the dealer and got an AC Delco gauge temp sensor in. Hopefully it will give me accurate readings tomorrow. I'm thinking I'll run between 170-190 most the time though.
Sounds like you'd benefit from it. Temps still seem a little high - was there a lot of air in the system when you bled it? Another thing you may wish to look into is a manual fan switch.
Henson071
08-04-2015 09:32 AM
squarehead
11-21-2014 08:02 PM
