A couple of valvetrain questions
First off i am wanting to use some 7/16 rocker arm studs on my car but i was wondering....Do you have to retap your heads for these to work? I mean i really don't want to mess with anything like that so would it even be worth it to retap the heads if i had to....Second...What is a REV KIT? Is it worth the money to buy if you had the money...Thanks for all of your help and advice
Michael
Michael
The 7/16" studs screw right in, but you will need different rockers for them. While your at it, since your getting different rockers, I would suggest going to a non-self-aligning rocker and hardended puhrods with guideplates. This will be a more reliable set up.
I've heard different things about the rev kit, someone else should give an opinion on that.
Hey thanks...btw the rearend is still holding up....thanks for the deal on the 4.10's....looks like you finally got your car lined out also....380 to the wheels? WOW that's pretty good....have you made any passes at the track lately?
No, not yet, its been so hot up untill this month. A buddy wants to go to Kennedale on Thursday but its rained the past two thursdays since it cooled off, go figure. Maybe this week.
Glad to hear the rear is still holding its own.
01-13-2015 09:52 PM
