Cracked head. What are my options??
Well, while I was off in Bulgaria serving my country, my dad blew a head gasket, possibly cracked a head. So what are my options now? While the engine is out I feel like I might as well start upgrading the completely stock engine. What do you guys think?
Is buying new heads the best route? which ones? from who? how much?
Should I attempt to p&p my stock heads? ( if not cracked )
Should I do a cam as well?
You guys know the ins-and-outs so any information would be GREATLY appreciated.
Thanks in advance
Josh
Thanks in advance
Josh
Re: Cracked head. What are my options??
The first course of action... figure out the extent of the damage.
May be that the head is just a little warped. Best bet is to take them to a reputable builder and have them check the head over for cracks/warpage. If they have some warp, you may be able to salvage them with some machining of the deck surfaces. If cracked, I'd chunk the casting unless I already had alot of money in the port work. Just not economical to fix a casting that you can find for ~$150.
Then you go from there.
As far as the stock casting is concerned, they are good for 400-450rwhp NA. Don't know your goals but that's a good deal of HP for a street engine. And yes, I'd definitely upgrade the cam in order to take advantage of the modifications.
-Mindgame
-Mindgame
If it's cracked you need new heads. What you do fromt hat point is up to you - heads are expensive. If you're on a budget i would probalby just get another set of stock LT1 heads as they can be had pretty cheap and there's a lot you can do with the stock heads.
cmsmith
09-14-2015 09:25 PM
cmsmith
08-20-2015 07:57 PM
