Crank Position Sensor is Leaking Oil
Old 07-08-2006 | 01:31 PM
EviLBoX's Avatar
Has anyone had this happen before? Do I simply need to replace the sensor? I had some maintenance done at the dealership and they found this problem, however I have yet to see any drops of oil on my driveway.
Old 07-08-2006 | 02:19 PM
moparman's Avatar
Re: Crank Position Sensor is Leaking Oil
There's an O ring that goes on the sensor. Try replacing that.
Old 07-08-2006 | 03:07 PM
96speed's Avatar
Mine leaked from the day I bought it to the day I sold it (2 engines, 3 cams, and 80k miles). I tried RTV, a blokc off plate (I ditched the sensor altogether), and it still leaked. It never affected oil level or did I consider it a "deadly" oil leak.
Ryan
Old 07-08-2006 | 03:50 PM
Hot94Z28's Avatar
Same here but put new sensor and RTV around the sensor hasnt leaked yet
Old 07-08-2006 | 04:06 PM
EviLBoX's Avatar
Think I could get away with just putting some RTV around my current sensor? It's not throwing any codes. Isn't the RTV sealant messy too? I won't have a problem getting the sensor off down the road will I?
Old 07-30-2006 | 10:26 AM
EviLBoX's Avatar
I assume I have to drain my oil to change the sensor? I know, dumb question ...
Old 07-30-2006 | 02:15 PM
moparman's Avatar
You don't have to drain the oil to change the crank position sensor.
Old 06-27-2007 | 07:43 AM
scottso's Avatar
Digging up an old thread - looks like I have the same problem. Just wondering how you made out EviLBoX - did you stop the leak - and how? I read that the sensor is sealed by and O ring - is that a dealer item? Also - looks like the sensor is just one bolt and it slides right out - is that right?
Old 06-27-2007 | 08:02 AM
1996-1997 crankshaft position sensor seal
AC-Delco # 219-194
GM p/n 10476885
The sensor slides straight out after the retaining bolt is removed.
HectorM52
07-30-2017 11:46 AM
eazyZ
03-01-2015 07:12 AM
Jessie4tin
01-07-2015 08:53 AM
Queens94z28
12-20-2014 09:11 PM
Injuneer
12-15-2014 09:36 AM
Quick Reply: Crank Position Sensor is Leaking Oil
