Crank position sensor and smog check??
I went in for a smog check today and I have codes 3 and 7, if i remember correctly.
It says my crank position sensor is malfunctioning but I changed that about a couple years ago. Do they go out that fast or is something else making it seem to malfuncion?
The monitor codes also said my 02 sensor, egr, and catalytic is not ready.
What will trigger all those things to be not ready? I have O2 simms in the back. Maybe the EGR is not working right?
Car runs fine if I put in my OBD1 pcm I got from www.pcmforless.com but with the stock OBD2 pcm it feels like it's lost a lot of power.
teal98
15
09-16-2002 01:23 PM
