crankshaft bearings??
Re: crankshaft bearings??
if the bearings are really bad the crank will have to be cut down , and u will have to use over sized bearings .... if not to bad you might can get away with just polishing the crank.
Different machine shops have different prices
low oil pressure ? do you hear knocking ?
if it has high miles and regular crank rods pistons , it be cheaper to buy a lower mile engine out of a junkyard
Depends on how much damage has been done. Best case you can polish the crank as mentioned and use a standard bearing. Worst case you need a new crank and the block needs a line bore. Either way you won't know until it's stripped and miced.
