Crankshaft Position Sensor (P0366)
Well, I finally got the car started today. Everything done to it is listed in my signature. The car seems to idle fine but under load it stutters like it has a misfire. However, it runs fine around 35-40 mph. It is throwing two codes which are both P0366. Do I have a bad CKS?.. vacuum leak?.. plug and/or wire problem? Anyone have any other similar problems like mine?
The crank position out of range code is set when the crank sensor speed does not match the low res signal from the opti.
Just recently my car was running horribly and the car was throwing a p0336. Symptoms were: backfiring, glowing exhaust manifolds, stumbling, and hesitation.
Per Injuneer's post to my thread:
"The CKP code is telling you the sensor's duty cycle is outside the expected range. Could be a faulty CKP sensor. But the PCM needs to compare the CKP data with something to determine the expected readings, and it may check the duty cycle based on the high resolution signal from the Opti.... hence a faulty Opti may cause a CKP code."
I replaced the sensor to no avail. Some research suggested to check the opti wire harness and electrical grounds near the coil. While I did have broken grounds, my car wasn't fully cured. A couple of threads I looked up with a p0336 ended with replacing a degenerating opti, but not all.
Finally I coughed up the dough and ordered a new opti, wire harness, and vacuum hoses. Engine running problems solved. Not trying to tell you to throw money at the problem, just letting you know what happened with me. Only in my case, I'm still throwing a p0336, cause after checking the new sensor, I found scratches which leads me to believe I have a loose reluctor wheel.
Good luck with your problems.
Odd.... you post the same question 4 different times on 2 different forums over a period of 34 minutes, and then you post the "thank you" on a thread that isn't even yours????
and I'm also having a hard time figuring out if the CPS would even cause the symptoms I'm expierencing. its fires right up but will stall right out if I don't hold my foot on the gas and no matter how much gas I give it it will only rev over 500rpms on the first second or two after I fire it up. I'm about to do the opti test right now how ever I don't see how the opti could of gone bad from sitting on the shelf, it didn't get banged around or wet at all.
It would be entirely possible for the reluctor to have vibrated out of position when hammering the hub on. It's really not the best way to install a hub. Still, if was all goobered up, it won't affect spark delivery. Also, used optis can get cranky just sitting around. The normal corrosion present on the cap and rotor terminals can grow if not kept in a cool and dry environment.
