Crankshaft pulley how to
Alright looking for some tips on removing the crankshaft pulley. Trying to change out the opti and appearently the pulley needs to come off as well. Any ideas on how to break the bolts loose and remove the pulley would be great.
Re: Crankshaft pulley how to
Remove the 3 bots that is holding it to the crank hub,trying tapping on it with a dead blow,rubber mallet..if that does not work use a 3 jaw puller and it should come off fairly easy.
From Shoebox:
http://shbox.com/1/4th_gen_tech1.html
http://shbox.com/1/pull_pulley.jpg
Do NOT hammer or lever on the outside edge of the damper. You will destroy the rubber ring that holds the inner and outer parts of the damper together.
PS: You need to add a "Signature" with basic info about your car - year, model, engine, trans and any major mods. That helps us hlp you.
Originally, it was a loose fit. When my car was new, the first time I pulled the 3 bolts out, it fell off. But at this point in your car's life, unless it's been pulled recently, the pulley/damper is fused to the hub with rust.
Remove crank pulley (three 5/8" bolts). Use claw puller if needed. The 1996-97 pulley may have some threaded holes in it between the spokes and look slightly different. You can use the threaded holes and a normal balancer puller (crow foot) to pull it off.
Thanks guys.... I was really looking for some thoughts on getting the bolts broken loose while not spinning the pulley. Is there a spot where I can put a screwdriver or something to keep this pulley from moving?
Thanks,
Justin
Thanks,
Justin
Again, a signature with some car info would speed up and insure correct responses that apply to your car. I've pretty much stopped posting help to threads with no car info. I figure if there is no effort to give car info, then the person is not serious about wanting help.
