crooked stance, sway bar or frame?
Old 03-26-2004 | 12:04 AM
Shue97_Z28's Avatar
my 97 Z28 has a crooked stance. in the front the car is fine, but in the back, the left wheel well is a half inch lower than the right wheel well, it doesnt sound like much, but to an **** person its agravating. i thought it was the frame, but the guys at the dealership said it could also be a sway bar? does anyone else have this problem? now i know f-bodys have a habit of doing this, but usually they sag on the right side. any help is appreciated. thanks in advance to anyone.
Old 03-26-2004 | 12:13 AM
95_LT1_6SPD's Avatar
Re: crooked stance, sway bar or frame?
sway bar thats an interesting idea, maybe they can hook you up with a lowering sway bar?
I would say the spring is sagging, or maybe you forgot to take your bags of water softner salt out of the left side of the trunk
Old 03-26-2004 | 02:31 AM
Shue97_Z28's Avatar
the new springs and struts i just put in didnt help at all, and they still dont have more than 6k miles on them now.
Old 03-26-2004 | 12:03 PM
Ace_437's Avatar
I think pretty much all F-bodies look like that over time. I've seen a million threads about it over the years. Mine sits like that as well. It kind of bugs me, but I don't think I'm going to worry about it much.
Old 03-26-2004 | 12:09 PM
scoobysnax83's Avatar
I definitely hear this all the time... It is very very common in older 4th gen F-bodies.
But, not to throw salt in the wound, mine has 167,000 miles on original shocks and springs and sits perfect. I did notice that the whole rear is a little lower than new f-bodies, but it actually makes the whole car sit perfect. Weird, I guess
Old 03-26-2004 | 01:19 PM
TraceZ's Avatar
It could be the swaybar. If it has a twist in it, the car will sit crooked. Disconnect it and see how the car sits.
If that is not it, and you really want to fix it... get a spring compressor/expander and stick it in one of the springs to straiten it out. I had an 87 IROC that sat crooked after an accident. The body shop insisted it was not the frame, so i used an expander on one of the springs.
Old 03-28-2004 | 06:59 PM
Shue97_Z28's Avatar
where can i get that and how exactly does it work? ill definately look into that cuz im sure its cheaper than a new sway bar, which might not even be the problem
Old 03-28-2004 | 07:14 PM
those things are dangerous... They have been known to randomnly shoot out on large bumps....
RUENUF
03-13-2016 04:37 PM
football4life
10-04-2015 08:48 AM
Daluchman1974
09-11-2015 07:12 AM
SpeedJunkee
07-19-2015 10:06 PM
