CSI or Meziere
Old 02-04-2003 | 12:22 AM
zmanlt1's Avatar
Question CSI or Meziere
I'm looking for an electric water pump, and all I come up with is the Meziere for around $200 and the CSI for around $135. Which one is a better water pump, and why? Is the Meziere worth the extra $65? I am building a stock bottom end LT1 w/ cc306 cam and AFR 190cc heads if that makes any sort of difference at all. Thanks,
Tom
Old 02-04-2003 | 01:33 AM
Trans-Am's Avatar
I think the meziere is worth the extra money. For one it fits right in side the old housing using the O-ring. Whereas the CSI you have to grind notches into the housing where the pump seals. Search around the sponsors on this site you might be able to find a pump for cheaper. Either way you cant lose though, go ELECTRIC!!!
Old 02-04-2003 | 01:59 AM
chesee48's Avatar
CSI i heard is better...less problems of the 2...
however after reading up, i'm just getting a stock-newer pump
Old 02-04-2003 | 02:08 AM
NiteRider's Avatar
We already touched this subject. Here check it out
Old 02-04-2003 | 04:42 AM
zmanlt1's Avatar
Thanks for all the info guys. I think I may go with the CSI. How much could you possibily need to grind out anyways?
Old 02-04-2003 | 09:38 AM
DaveW 396ci's Avatar
I should have taken pictures when I installed mine. The grinding isn't that big of a deal. You have the housing all apart anyway to remove the stock drive and blades. It is laziness to not save the $65 and spend a few minutes to grind with a dremel.
BTW, the CSI also seals with an o-ring just like Meziere
DaveW
Old 02-04-2003 | 09:42 AM
Bryan Smith's Avatar
Thumbs up
http://ken.lowrance.com/projects/CSIwaterpump/
Ken did an awesome job writing this tutorial. Take a look.
I used it when I installed mine.
Thanks Ken.
Old 02-04-2003 | 12:38 PM
chesee48's Avatar
yep...
RUENUF
03-13-2016 03:37 PM
HarleyZ28
10-05-2015 06:23 AM
lbrowne
11-13-2011 04:25 PM
Zone
07-29-2002 07:43 PM
Quick Reply: CSI or Meziere
