Cutting my stock springs: Good, Bad, or Horrible idea?
I really want to lower my car about an inch, but can't afford to buy a Pro-kit right now.
I've got all the tools needed to cut my springs and was wondering what people thought about this? I know i've heard that you can weaken it by heating it up and stuff, but I would just be using an air grinder to cut it. How many problems could I run into doing this?
Like I said, I only want about an inch drop all the way around, I've got a cutout and the damn thing is already low enough.
Thanks in advance,
Kyle
Thanks in advance,
Kyle
Originally posted by ArcticYT95TA
Absolutely horrible idea. I wouldn't ride in a car with cut springs.
Thanks so far though.
Re: Cutting my stock springs: Good, Bad, or Horrible idea?
Thanks in advance,
Kyle
Thanks in advance,
Kyle
If you only want a 1 inch drop, you'll only need to shorten the fronts about 1/2 of that because of the "motion ratio". The springs don't act right at the lower ball joint. For the rears it's about 1:1.
If the springs have a closed and/or flat ground ends, there is no good way for you to cut them. On the other hand if one end is "open" and not closed up against the next coil you could cut.
The problem is that if you don't do things correctly you trash the springs, and you have to buy something anyway.
If you shorten springs and therefore lower your car, you need to get an alignment which is more money. If not, you'll probably mess up the tires, which is more money. One inch shouldn't throw camber screwy like the slammed ricers, and alignment should work well. It's probably toe that will change most.
It CAN be done correctly, but most often is not.
Bottom line is: you proably shouldn't try it. Wait until you can afford the Eibachs and the alignment.
If you have access to the book Chassis Engineering by Herb Adams (Barnes & Noble often has it on the shelf), Herb has a chapter on shortening springs. Read that for more info. Herb is one fine practical (and theoretical) engineer. I knew him before either of us had grey hair, and most of you guys weren't yet born.
Please explain. I know people who have said this, but no one has ever said WHY that's the case. What does cutting them do? My best friend cut his '00 GT's springs and it was great, never a problem.
A spring has a set number of coils, and they are what is used to absorb energy. Also wieght is handled by them as well. Depending on the thickness of the coil and the rate at which they progress, is how they are rated(ie weight load, stiffness,ride hight). Cuting one of these coils off messes this all up and the spring may or may not be up to normal
punishment.
I've got a deal for ya! Come up to Austin and swap me your stock spring/struts in front and your stock rear springs and I'll give you my RK sport lowering spings FREE.
I really need to go back to stock hight with the 4" mufflex system.
Let me know
512-576-6452
Chris
Let me know
512-576-6452
Chris
Some of the tech magazines have had decent results with this. Just as long as you cut with something that doesn't heat the springs and you start conservatively, it shouldn't be too bad. Just cut small pieces off at a time so you can get just the right stance.
If you want to cut your springs now that's great but I would still suggest getting new springs and shocks later on down the road when you have the money.
---- And you may need to change the alignment- the more you lower the more important this will become- unless you like only wearing out the inside part of your tires
Originally posted by faded93bird
ok heres my take on that
punishment.
punishment.
In the case in point you might see 5-10% increase in rate at most. This actually helps keep the car from bottoming.
I'm not talking about ricing it 4 inches or so, just the mild amount Kyle wanted.
Let me know
512-576-6452
Chris
Let me know
512-576-6452
Chris
Oh, and by the way, the alignment part shouldn't be too much of a problem. I just got it aligned at NTB not too long ago and all I'd have to do is go up there again and they should redo it for free. If I don't do the swap with t-trim then I'm gonna look into that book on suspension.
Thanks for the help guys,
Kyle
Damn, I was just in Austin last Friday for a few hours, too bad I didn't know then! What kind are they off there? And how much does it lower? Let me know.
I'm serious about this swap. I just had my exhaust fixed for the last time yesterday.
They are from RK sport, and they lower 1.5" in front and 1.75" in the rear i think.
Hack Away! it's kool! People have been cutting springs for years.. there are even some low buck road race cars out there with cut rear springs.... just make sure you don't go nutz and hack it in half cut small and re-install until it's low low low.... I've done it and tons of people i know have! it's called old skool! if you don't have it or can't afford it... Make It!
01-05-2015 07:14 PM
Lt1son
12-31-2014 01:35 PM
