Dangers of the LT4 KM
Old 06-04-2004, 07:57 PM
SpeC's Avatar
Exclamation Dangers of the LT4 KM
Hello. I was wondering if there are any dangers of installing the LT4 Knock Module to our cars?
SpeC is offline
Old 06-04-2004, 07:59 PM
25thBird's Avatar
I doubt it. I haven't heard anything on that. If anything, it would make your ride better.
25thBird is offline
Old 06-04-2004, 08:00 PM
Kryckter's Avatar
I have not heard of any. It de-sensitizies the knock sensor. It can be used for many things such as loud exhuast or roller rockers that create false knock. I have never heard of it being damaging becuase it still works, just on a lower scale
Kryckter is offline
Old 06-04-2004, 08:13 PM
SpeC's Avatar
Thanks guys. Next question. Wheres the best place to get one?
SpeC is offline
Old 06-04-2004, 08:22 PM
25thBird's Avatar
Ebay... $40 to $45 new...
25thBird is offline
Old 06-04-2004, 08:38 PM
whiteslpz's Avatar
The last time I checked they were only like $30-35 at gmparts direct.
whiteslpz is offline
Old 06-05-2004, 12:52 AM
1 Nasty Bird's Avatar
ya but gmpartsdirect wants like 386.84 to shiop a knock sensor next door. Ok its not that bad but tehyre prices are low because the shipping is totally outrageous ive noticed.
1 Nasty Bird is offline
Old 06-05-2004, 12:55 AM
bdc95ta's Avatar
Mr. Jason Cromer! Just dealed with him at the beginning of this week great guy.
bdc95ta is offline
Old 06-05-2004, 07:18 AM
Cmr0z28's Avatar
Actually www.gmpartsdirect.com only wants $8 to ship an LT4 knock module. I priced them out, and it's actually a little cheaper than Jason Cromer after shipping since he wants a dollar or 2 more, and the same amount to ship it.
Cmr0z28 is offline
Old 06-05-2004, 07:19 AM
LameRandomName's Avatar
No, it doesn't...
First thing I should say is, we're talking about the knock module, not the sensors. You leave the sensors in the motor and just replace the module, which has the software to, theoretically, tell the difference between engine noise and knock.
The LT4 KM isn't less sensitive, it's more accurate. You will be less likely to get false positives, which lead to retard when you don't need it.
LameRandomName is offline
Old 06-05-2004, 11:35 AM
96capricemgr's Avatar
Originally posted by LameRandomName
No, it doesn't...
This is the best explaination I have seen of exactly what the LT4 KM does, .
96capricemgr is offline
Old 06-05-2004, 01:57 PM
bolek's Avatar
What if you desensitize through programming?
Can you still benefit from LT4 KM, and what is
the difference between the two ?
bolek is offline
Old 06-05-2004, 02:57 PM
stereomandan's Avatar
When I asked Ion at www.madz28.com about using the LT4KM with the desensitized PCM, he said that they are supposed to work together. So yes, you still use the LT4KM with the desensitized PCM.
I am.
Dan
stereomandan is offline
Old 06-05-2004, 03:06 PM
SpeC's Avatar
any1 have a part #? and will this work with my JET Chip?
SpeC is offline
Old 06-05-2004, 03:32 PM
LT4 knock module part number 16214681
Yes, it will work with any chip/tune/reprogram...
Dan
Quick Reply: Dangers of the LT4 KM
