Deleting EGR & AIR
#17
Originally posted by FacelessZ
Ok so I have one black tube on the drivers side that is sucking and one black tube that is blowing...what do I do with these?
Any immediate help would be appreciated!
#18
OK
For some reason I've suddenly got the urge to remove AIR, but not EGR.
Now, I've been searching through the forum and reading the guides and what not, and am still uncertain as to the exact specifics of everything. I need two 18mm oil drain plugs to block off the holes on the exhaust manifolds? And two vacuum caps for the intake and intake manifold?
Here's a picture: http://ignitersoftware.com/camaro/Image1.gif
Now, there you will see shoebox's lovely photography skills. On the top left I have an arrow pointing to where I believe the oil drain plugs screw in. Tell me if that's right.
Then in the rest of the sections in that picture I have highlighted every part of the AIR system that needs to be removed. Is that all correct... what's highlighted?
So I just need to rip that stuff out of there, along with the AIR pump, the bracket it mounts to, and the solenoid "module" with it's little vacuum lines? I just want to be sure I know everything before starting this.
Thanks guys!
Thanks guys!
#19
Need to remove these components.
http://www.97ta.com/lt4/lt501.jpg
Need M18 drain plug for 96-97.
http://www.97ta.com/lt4/lt495.jpg
3/4" vacuum cap.
http://www.97ta.com/misc_pic/misc57.jpg
EGR blockoff plates.
http://www.97ta.com/lt4/lt480.jpg
http://www.97ta.com/lt4/lt481.jpg
And a small vacuum cap for the fitting on the intake manifold (vacuum source for EGR solnoid). I forget what size, but it's pretty small like a 1/8" vacuum cap.
Have PCM reprogrammed (OBD2).
http://www.97ta.com/lt4/lt487.jpg
3/4" vacuum cap.
#21
My block off plates are home made 1/8" thick polished stainless steel. You're more than welcome to use my dimensions.
http://www.97ta.com/misc_pic/misc83.jpg
#22
Here is a website that sells them:
http://www.mycamaroz28.homestead.com/Index~ns4.html
or you can just make them yourself like AsianSensation said.
#23
[QUOTE]Originally posted by Josh-'97 WS6
[B]Go back and reread my last post. The '96 LT4 Grand Sport Corvette had NO EGR from the factory. GM Powertrain deemed the overlap on the LT4 cam as enough to make an EGR system unnecessary.
Does this also apply to the LT4 Hot Cam?
#24
Sorry to see no body talking about the function of the sys to understand the effect of deleting it.
exhaust-gas recirculation:
(EGR) An emission control system where some of the exhaust gases are rerouted from the exhaust manifold into the combustion chamber to make sure that all fuel is burned before entering the atmosphere. The process lowers the combustion temperature and reduces the formation of oxides of nitrogen (NOx) in the exhaust.
If it lowers the combustion temperature, that means if it's removed, higher temperatures will be reached. That translates to more compression and hence more power.
#26
A more important side benefit of the EGR system is the fact that it reduces the tendancy of the engine to detonate under "lugging" conditions.... i.e. - too much throttle in too high a gear.
armedtrigger
02-24-2015 08:30 PM
MIGHTYMOUSE
08-29-2002 09:18 AM
