Delteq Opti replacement
#16
The design flaw of the optispark was only the high voltage side. The optical sensors and encoder wheel are as close to bullet proof as you can get.
I removed the front half of my optispark years ago and sealed the rear chamber. You can also just pull the spark plug wires off and leave it there. The automatics still use the hi/lo rez signals for shifting.
The Opticrap legend is also exagerated with the aftermarket MSD boxes that increase the voltage through the distributor.
The Delteq company is going for the heart of the problem of LT1's. It is the perfect cure for the Optispark.
Good Luck
Good Luck
#17
I've gotten the "low res pulse error" code a few times, the optical side isn't bulletproof, however it is more reliable than the other side. If the bearings were higher quality, the optical side would probably be bullet proof. They tend to rust, and obviously rust+optical sensors doesn't work out too well. I'd rather just get rid of the whole damn'd thing
Carson
Carson
Good Luck
Good Luck
#18
I dunno...out of the 2 T/A's I have had I have yet to have an opti fail on me, and if it does its less than $200 to replace...so I could buy 3 opti's for what all these other systems are costing me...
BTW the first car had 79k miles and this one has 72k miles...all on the original opti...
#19
You are a lucky soul
A friend of mine just bought a T/A, it runs good but has a slight miss, so he's replacing the opti. It'd probably last a lot longer, but isn't running quite right, not sure if you would have noticed any improvement had you replaced the opti anyways, but its definetly possible. Many people have reported their cars running better than ever before after replacing an opti.
Carson
Carson
#20
Delteq GP
There is a thread in the GP section checking for interst in the Delteq GP....
http://web.camaross.com/forums/showt...22#post2143122
#22
#24
I have the money to greatly decrease the chances of the opti killing my car or causing problems. So since I need to replace my opti, I'd rather just upgrade this once and get it done with.
Also, I've read the DELTEQ offers a stronger spark. Interesting stuff.
#25
Hi guys for those who are interested i am having a GP on the delteg Below are the links.
http://web.camaross.com/forums/showt...hreadid=260824
http://web.camaross.com/forums/showt...hreadid=263358
or you can view the prices at http://www.elitesparkplugs.com
10-31-2016 11:09 AM
grabbem88
03-18-2015 01:25 PM
Alex Barnes
01-24-2015 10:21 PM
