Delteq and Timing
Delteq and Timing
While rebuilding a '96 LT1 and using a Delteq, is it important to set the timing gears at 12 o'clock and the opti dowel pin at 9 o'clock as per HPBooks "How to Rebuild SBC LT1/LT4 Engines" instructions? I already installed the TC cover and I forgot to set the gears and I thought that using a Delteq might eliminate the need for this. Sorry if this is a dumb question, Im a noob. Thanks
Re: Delteq and Timing
Originally Posted by framelayin84
I think I have the gears set right, they just are not at the 12 o'clock position, they are both at the 1 o'clock position. Does it really matter?
Setting the cam and crank gear dots is for correct valve timing and must obviously be done first.
10-31-2016 11:09 AM
ChrisFrez
02-01-2015 08:26 AM
