Is delteq worth it?
#16
Re: Is delteq worth it?
The Delteq system is easier to install. it is just plug in and play. As for the ltcc, you need to cut into the wiring harness and find the correct wire. Also, mounting the coil isn't as easy as the Delteq, either. There as been several people whom have had trouble installing the ltcc. Something about finding the correct pink wire. No such trouble when installing the delteq. The whole system cam only be connected in one way.
AS for the proformance, I would bet on the dyno there isn't a difference!
#17
Delteq is definitely worth it. I had a really bad miss throughout the RPM range. Huge loss of power, strong gas smell inside the car and out, and a overall crappy driving experience every time i had to take it out. I put the delteq in in about 2 hours and everything is as good as new, never been better. If you know its your opti and its not throwing any codes, than this system is 100% worth it.
colts0455
09-02-2015 12:41 PM
mark0006
08-29-2015 09:45 AM
