did anyone cut out splash guard after cai install?
Old 07-04-2003 | 01:50 AM
cals400ex's Avatar
i was just wondering if anyone cut holes or modded the splash guard after installing a cai? i am highly thinking about it but don't know if it is worth it or a waste of time. i would think that it couldn't hurt because this car is not out in the rain. also, did anyone who did this notice any minor time slip differences at the track? thanks
Old 07-04-2003 | 01:59 AM
Antz97ZNJ's Avatar
I didnt even put my back on ...too lazy
Old 07-04-2003 | 02:19 AM
pennys58's Avatar
If you want to put it back on and do this mod...
http://www.charm.net/~mchaney/ramair/ramair.htm
it couldn't hurt.
Old 07-04-2003 | 06:24 AM
JetLag's Avatar
I cut my splash gaurd out, it never rains around here.
Old 07-04-2003 | 10:26 AM
Derrick Redd's Avatar
Same here.
Old 07-04-2003 | 10:38 AM
ibanez6rg's Avatar
Ditto
Old 07-04-2003 | 11:10 AM
TsRfBoDy's Avatar
I put mine back on, but I was worried about to much dirt and mine is driven in the rain. Plus when I go to the track I just take it back off, it only takes 5 minutes
Old 07-04-2003 | 11:14 AM
1msfyter's Avatar
Ditto. Cut square hole. It gets a little dirtier. But it breathes
Old 07-04-2003 | 11:49 AM
ChickenScreamer94's Avatar
i did the "up-side down ram air" mod pennys58 had a link to. Works ok.
Old 07-04-2003 | 11:59 AM
Smokn '94 Z's Avatar
Lightbulb
I cut mine too. Cannot tell if there was a significant difference though...
Old 07-04-2003 | 12:59 PM
Mtrhds94Z's Avatar
I cut the triangular part in front of the air dam out...
I figure it pressurizes it some just like the radiator..
Good compromise to the scoop I think..
Old 07-04-2003 | 01:51 PM
stereomandan's Avatar
I didn't cut mine, and am glad that I didn't. I would always be worried about sucking water into the intake if I cut it. I still noticed a big improvement with the CAI install even though I didn't remove the plastic.
Dan
Old 07-04-2003 | 03:24 PM
revtime's Avatar
I never put mine back on either.
With the filter mounted low like that it won,t matter whether you have a splash guard on or not if you run through deep standing water.
I have to clean my filter more often but I just avoid rain and NEVER go into standing water.
Old 07-04-2003 | 03:32 PM
97 RedSS's Avatar
Yeah..just cut it off and leave it..Im sure its worth a tad bit if power..
Cody
Old 07-05-2003 | 01:59 AM
cals400ex's Avatar
did you all remove the black plastic piece that sits right behind the headlight? i guess this is where air comes from under the headlight on the factory intake. there is actually one of these pieces that is in the left fenderwell that i removed but i did not remove the one right behind the headlight.
Quick Reply: did anyone cut out splash guard after cai install?
