Dies after idling at 2k
I drove my car to work this cold morning (at work now) and i noticed that it was idling high whenever I put the clutch in or put the gearbox in neutral, it would always be above 1500 and below 2000 while I was rolling, but once I came to a stop the idle would become normal, I thought that it was just because it was a cold start, but when i go to park the 'bird, and i actually stop, the idle went down to normal for a about 5 seconds and then proceeded to die on me... I had no time to look anywhere yet, possibly on my lunch.
Also, when i tap or step on the throttle, it is like it chokes or hesitates then jumps up, and back down to the abnormal idle RPM.
What could be the problem?
