Dino or Sythetic on 1st 50mile break in oil change??
I used dino oil on start up.. I have 50 miles on the car and was going to use regular oil again.. and then at 500 miles i was going to switch to synthetic...
And when i switch im going to give it wide open throttle and really feel the power again !!!!
so what do u prefer for the 1st oil change?
Re: Dino or Sythetic on 1st 50mile break in oil change??
Originally Posted by 1racerdude
Run dino non detergent for a couple hundred miles then whatever you want.
ALso, those initial critical miles are rather mute, if the engine was not allowed to seat the rings effectively. If the engine was driven mildly during those initial miles, it is a mute point.
grabbem88
03-18-2015 01:25 PM
