Dipstick loose on 93 Camaro Z28
Old 02-21-2013 | 09:28 AM
Nate88's Avatar
My dipstick is loose on my '93 Z28. I have read several different forums on how to fix this, but the problem is that my car has been lowered and I can't get under it good enough to fix the problem. So, I called a few local mechanics that I knew had lifts, and they are telling me that the engine will probably have to be pulled to fix the dipstick. Does this sound right? None of the threads that I have read have said anything about pulling the engine to fix the dipstick. I am not looking to drop $1,000+ to get a dipstick fixed, and I know that is what it will cost if the engine has to be pulled.
Old 02-21-2013 | 10:17 AM
Locruid's Avatar
Re: Dipstick loose on 93 Camaro Z28
I pulled mine out on my 95 from up top. Only a single bolt holds it on then just pull up. I ain't never had to pull a motor in my life to pull a dipstick.
Old 02-21-2013 | 12:44 PM
RamAir95TA's Avatar
The above poster is correct. There's a single tiny bolt that holds the dipstick in place. Figure out how to get to it.
Just because it's lowered doesn't mean the underside of the car is inaccessible.
Old 02-21-2013 | 01:21 PM
bowtiedad_z28's Avatar
I just replaced mine because it had the weld on the bracket to the tube broke and making it loose as well as it caused a hole in the tube. My car is lowered as well,so i just put it up on stands and changed it. I accessed the bolt through the bottom.
CamaroHeed
03-18-2020 09:50 PM
NewsBot
12-28-2014 06:20 PM
Brandon Wittmer
12-03-2014 09:28 PM
grendal
04-15-2010 05:20 PM
2000silverz28
07-20-2002 06:14 AM
Quick Reply: Dipstick loose on 93 Camaro Z28
