Disabled VATS, now can I...
you could take the key out of your thirdgen becuase the teeth and tumblers were worn down quite a bit. i used to be able to do that in my thirdgen but when i had a new key made i couldn't. being able to pull it out has more to do with age then with the chip on the key.
why an dhow did you disable it?
If you don't know how to do it, check out this website for the resistor values you need to try, if you don't know what your key is.
15 resistor values
08-07-2015 08:52 AM
