Dissapointed in LCA's! Or is it the weather 39Degrees.
I am wondering if I stil can't hook up better with my new BMR LCA's because it is in the high 30's outside. I was expecting a night and day difference, I just feel the rear more solid and the traction feels close to the same. Would greasing the zerk things wrong affect it? I am puzzled whether they were not that big of a help or just the cold weather is killing my traction.
I had the same issues.. I installed my BMR LCAs and didn't notice any difference at all. It seemed more solid in the rear end but it almost seemed to spin easier because of this, especialy coming out of corners. I only got to try them when it was low 30s outside though and people on here told me that the temps were really hurting them. Im going to try some relocation brackets followed by an air sack come spring.
Aaron
Aaron
The cold weather is what's screwing you over. Your gonna spin bad even if your running drag radials if the ground is cold. I spun so bad the other day the car was starting to get sideways, and it was like 36 degrees out, not even freezing. It's too cold, especially if you live up north, at this time for any kind of drag racing. Traction is a bitch on a cold road.
After doing some more driving today I noticed that the rear does plant the tires better slightly, its a different feeling than before, the traction I am sure will greatly improve with the warmer weather. The tires will not spin as long but hook up and it feels like the tires are being forces to plant and gain traction.
Originally posted by 94 CAMRO Z28
I had the same issues.. I installed my BMR LCAs and didn't notice any difference at all. It seemed more solid in the rear end but it almost seemed to spin easier because of this, especialy coming out of corners...
If your car is lowered, relocation brackets can restore your geometry and improve traction, but can hurt high speed stability if you use the lowest holes for maximum anti-squat.
DaveH
WobblySausage
10-07-2015 10:09 AM
