Distributor
Re: Distributor
The only one currently getting decent reviews:
https://petrisenterprises.com/
Unfortunately they are out of stock due to COVID affecting parts supply.
Re: Distributor
If you're willing to try it out, some guys are moving away from the optical sensor by going with t he 411 LS PCM.
I picked one up at my local yard out of a truck for $35. Since you have a 97 with the reluctor wheel and crank sensor, you may want to ultimately go that route as well. It's a little more in depth, but it will rid you of that sensitive opti sensor.
Re: Distributor
Question on youtube vid (411 pcm with opti))
Re: Distributor
Are you referring to the YouTube video. Not problem free.... engine runs in batch fire rather than sequential:
