DIY Engine Pre-Oiler
Looking to see if anyone has made one. I researched using a pressurized tank. Like an accumulator, but it looks like that is more than I want to spend considering it will not be used often. I then thought of just using an old oil pump. Anyone tried this? The idea is to mount the pump on a piece of scrap metal and clamp that to a bucket with the pickup hovering near the bottom. Add oil to bucket and use a drill to spin the pump. Were can I connect the oil line though? I do not want to takeoff the oil pressure sending unit. You think this would work?
Jeff D.
Jeff D.
JasonD
08-23-2010 03:14 PM
Caps94ZODG
22
07-30-2002 08:45 AM
