Do I have to actually remove the stock sxhaust manifolds, or can I just unbolt them ?
Do I have to actually remove the stock exhaust manifolds, or can I just unbolt them ?
Taking off heads to get them to machinist, to save some time can I just unbolt the exhaust manifolds to get heads out ?
Yeah once you get the manifold bolts out the only thing keeping them in the way would be the Y pipe bolts, so you might as well take em out and get them outta the way.
It will make things less frustrating.
I guess I will take all's advice and drop the y-pipe, I am just looking at those rusted bolts on the Y-pipe and I dont get good feelings, wonder if I should just break them all off and spend half a day drilling them out and replacing them, I'll have to do a searcg to see the part number for the studs.
you really need to hose all the bolts down with pb blaster a few hours before you take them out. Thye Y-pipe bolts are probably going to break anyway, so get ready for it...
Or you could replace them with some used headers which you can get as low as $100 sometimes, so you don't have to worry about broken Y-pipe bolts
I dont see any headers about cheap. I am thinking about snaping off the studs and just replace them, should save me some time,are they hard to replace?
I PBed them yesterday so we'll see in a hour or so.
99TransAmWS6
02-03-2015 08:27 AM
