Do I need this??
Do I need this??
I want to remove the condenser (radator in front of actual radator) and I am wondering if I take it out and have the a/c by pass it will the a/c still work. I know it wont work as well but will it work.
You have to remove the heat from the circulating, vaporized freon. That is the job of the condensor. It removes the "heat of vaporization" and the gas condenses into a liquid, so it can flow to the evaporator, and absorb heat when it evaporates. No condensor = no heat removal.
