does all fbodys have the same rear carrier?
its either a 2 or a 3 series carrier, if your rearend came with 2.73s then you have the 2 series and will need to upgrade to a 3 series carrier if you plan on doing gears. If you have 3.23 or 3.42s then you will have the 3 series and will not need to upgrade. Speaking in F-body gear ratios, vettes will vary, i think they have a 2.59, and a 3.07. Anyway, you get the jist of it.
Brian
Brian
Originally posted by 97SS0594
i belieive the 2002 fbodies have a diff size ring and pinion, but before that you could take the gears out of a s-10 and throw it in your camaro
You will not have to change the carrier. dont listen to them people I have a brand new set of 3.42 from strange that allows you to use them in a series two. checkout thunderracing and you should find them.
Who exactly are you telling him not to listen to?
