Does rear end differential cover have gasket underneath?
If so where can i get one? Need to take off differential cover to check out the inside. Also which is the best rear end fluid to use? Thanks in advance.
Originally posted by gamboa
Thanks for the info. Hey can i get that Royal purple synthetic at pep boys? Do you need to replace the Diff. cover with a torque wrench?
Have any local speed shops? They'll have it.
10-31-2016 11:09 AM
